Boycedrilling
Don't think that would have worked on the pump I pulled yesterday. 125 hp submersible set on 525 ft of such 40 6" steel pipe. That 4/0 wire is a bear to handle. Takes twice as long to set or pull as a 60 hp on 4".
That thing was made here in Ct. An up z dazy is a better machine, a pull a pump is even better.
This is what we bought for people on polly pipe & home builders/well drillers that drilled a well in the backyard where you can't get to with a rig truck.
In the stickies section, there is good thread about chlorinating a well. Have to be sure to recirculate it thru the cap for some time. Have to do more than just pour in chlorine, at least if you have a pump in the well.
You are correct, we do have to run the water until you smell chlorine but most of time we can't get into the house, so the customer has to run water to each faucet
Inside the house, we can go as far as an outside faucet on the side of the house.
WellDown was trying to figure out how to fist pull the galvanized 20 ft-long pipes that go to his pump 365 ft down.If it was my own well out in open, I would take a rim that most people have lying around, rig the rim up over the well where it can spin & is not going to fall over, then grab my truck and tie off the polly pipe to my truck, so I can then walk it out with the truck while the polly pipe rolls on the rim.
You need to read the footnotes on a wire chart. The distances in BOLD print are only for individual conductors in free air or water. The remainder of the chart includes double jacketed wire or wire in conduit.
Sorry, not going to run individual wires, in an uncased well. Actually any more I only use flat jacketed double insulated wire for everything. I'm not going to stock two kinds of submersible wire.
The "finger smasher" homemade rig, for pulling steel pipe, we had this rig before the big rig in the early 60's.
Or you could make a home rig like ours but upgrade it to handle the more weight.
File size:
135.2 KB
65
