Ufengineer
My well is located inside my 14x16 foot shed about 3 feet from the exterior wall. I currently have two 1.25" galvanized pipe in the well. I believe 60 feet deep. The pipe is in 5 foot sections because there is no hole in the shed roof. I was going to try to reuse the galvanized pipe but have concerns about galvanic corrosion between the stainless pump and pipe.
My options are:
-put in a 5 foot section or fitting of sch80 pvc then galvanized pipe the rest of the way
-put in 5 foot sections of sch80 or cut a hole in the roof and use 20 foot sections
-Use 160 psi rated poly
Am I missing any other option.
I'm thinking that I'll need about 70 feet of pipe. Water table is 40 feet down
Which do you consider the best option for longevity and easy of upkeep.
My options are:
