I have a Oase Nautilus 60 pump about 20 years old. It is in a very specific application. basically since that pump is no longer in existence and a used one seems a long shot I am kind of grasping at straws here. It is making a bad noise (Bering). When I opened it up I found a grundfos water motor. My problem is I can't see how to get into the bering if that is even possible. The back end seems to be sealed except for a stainless steel plug to add water. The front end with the impeller has to be the way in maybe. Behind the impeller is a metal plate a rubber gasket between another metal plate. All I can think is these are glued together and if pried apart the rotor and bearings would come out. Any ones thoughts on the issue would be greatly appreciated.. Also A long shot but maybe that grundfos motor was used in other applications but how to find out Thanks Matt
