Strange problem with baseboard behind toilet
Andrew Wood
St Louis, Missouri
I just moved into a new place and this started happening behind a toilet. Has anyone seen this before?
  • Baseboard doesn't feel wet
  • Primer and paint is stripped but not on floor
  • Placed toilet paper on the floor and no water was on it after a week.
Thank you!
CountryBumkin
Active Member
Orlando, FL
You said your in a new home, so I assume this satin was there when you moved in.
I would think someone got the wall wet (maybe cleaning behind the toilet) and it caused a stain. If it is dry, paint over it with a stain blocking paint primer (like Kilz) then top coat and I'll bet that's the last you see of it.
Andrew Wood
St Louis, Missouri
The beadboard and new baseboard was put up about a month after moving in which was two months ago. I'm just confused how the caulk looks damaged and the water is around the pipe, not directly below.
CountryBumkin
Active Member
Orlando, FL
Okay. Maybe leak inside the wall? Can you pull the escutcheon plate/cover and see if anything is wet around or below that fill line? How hard would it be to pull off the baseboard (is a short piece)?
CountryBumkin
Active Member
Orlando, FL
It's not the color stain I would expect to see with a water leak - but I don't have any other ideas.
Maybe one of the Pros will see this post and have a better idea.
Plumber69
Prince Rupert, British Columbia
Is it a painted metal escutcheon? If the escutcheon is old it will react with the copper. If ur flapper is shot cold water will always be running and condensation will occur. I suspect rust from the escutcheon due to condensation
