Palm Sands Ranch
Hello all, needing help with a new set up. I catch rain water and haul water to fill above ground water tanks, I am putting in a new manufactured home that will be appox 160' from the tank, it is nearly level ground. I will be burying a water line from the pump to the home, need help with sizing a good non-submersible pump and pressure tank to handle that distance and provide good pressure to the house. The pump will be sitting right next to the water tank. Currently I have a Harbor Freight 1hp shallow well pump with its own pressure tank (small), it does a great job with pressure connected to a 3/4" 100' garden hose but I know the cycling would burn it up in no time if connected to a home. Would sure appreciate any help given. Thanks
