Square D pressure switch
Fitter30
Peace valley missouri
Didn't know they made a switch like this one. Has a built in low pressure safety. Pressure drops 10 lbs lower than on contacts turns pump off. Manual reset
SKU
9013FSG2J21M4
The switch with the lever sounds more useful than it is. For one thing, after a power outage, you would often have to hold the lever to get going again.
If you rely on that feature to detect a well going dry, it may not trip out. If the well is sucked dry before cutoff, the pump can continue to run, sucking air, for a long time. I had a softener that got stuck in backwash overnight. It pumped the well dry, but the well was constantly refilling at a rate less than 2.4 gpm. So a mix of water and air got pumped up for a long time. I wish I had checked the pressure gauge before putting a stop to the problem.
This is not to say that it is not sometimes useful to do what you want. It is definitely cheaper than the more-effective dry-well devices. Those devices detect the current drop as you run dry, and turn the pump off for a programmable amount of time.
In https://terrylove.com/forums/index.php?threads/frugality-at-its-finest.82903/ LLgetfa said
I looked at the Square D I had with low cut-off and figured out that I could lobotomize it. I removed the little metal piece that trips it and so now it is a standard pressure switch.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I agree with Reach4. It only sounds useful and can be a downright nuisance and/or can give a false sense of security meanwhile the pump can still melt down.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
SKU
9013FSG2J21M4
Yeah low pressure cut off switches are a very common nuisance. Many people use them. As was said, they are not as reliable for protecting the pump as a dry run relay like the Cycle Sensor. Model number ends with an M4 means low pressure cut off.
