PaulN
Hi from DIY frustrationland. Glad this forum showed up in a search...looks like you've seen it all!
In our little-used tub/shower, hot was fine, cold was very low flow. After replacing the balancing spool and cartridge, and checking the stop check valve, I took a pic today down the barrel of the Moen single-handle faucet, c. 1987:
Something dark like a washer or o-ring seems to be blocking the cold-side port from the balancing spool. I could feel it with a bent wire but couldn't get it out. And 70 psi from our well pump wouldn't budge it, just dribble around it.
What do you think might work?
Thanks,
Paul
Thanks,
Paul
