[SOLVED] How do I safely turn the water off for shower repair? So many handles!
guido
chatanooga
https://imgur.com/a/NNF6jhf
We have a tankless heater. I tried the following:
  • Turned tankless off with the power button.
Pic1:
  • Turned off green handle,
then had shower running, it seemed one of the 2 (cold & hot) turned off, but not the other.
  • So I turn off black.
The water slows down, but still more than a trickle, and after a couple minutes, it's still like that. I looked at all the valves at the tankless - Pic2 .
  • I flipped yellows
but then that pump that sits between started making a different noise, which made me insecure about what I was doing.
  • I reverted all and made photos and came here to ask:
If there is a recirc pump, then power to that gets turned off first.
The first incoming shutoff for the cold is the one I use when doing a shower repair. It doesn't do much to turn off the hot but leave the main cold on.
Sometimes I shut it off at the water meter.
Is this the recirc pump:
Or is that the gas coming in, and should I leave that alone?
Does it help if I shut off red and blue at the tankless?
It's definitely in recirc mode, but I thought that pump lived inside the tankless unit
Update: got it figured out, thanks @Terry!
I ended up looking at my tankless specs, mapped what was what. The gas was not that pipe, so it was indeed a circ pump.
Turned that off, tankless off
then closed pic1 green & black
pic2 red & bottom yellow
Water trickled for a while, but eventually stopped.
