Solar Pump Issues
TJanak
South TX
I'm relaying my Dad's story, so I'll try to keep it short and to the point.
Solar pump running into 1400 gal cattle trough with float. Thunderstorms come through with pretty good lightning storm. Three days later notice cattle are out of water. Not pumping. Well man says to diagnose, take leads from pump and hook directly to a generator. This is done, no water pumps. Then says to hook pump leads directly to solar panels, again no water. After doing these tests control box and circuit board is inspected and looks fine. Hooked everything back up as should be and still no water pumping. Come back the next day and board in control box is burnt. At this point removed pump leads from control box and ohmed:
Red lead to ground: 1.4-1.7 ohms
Black lead to ground: 0.0 ohms
Red lead to black lead: 0.0 ohms
Swapped tester leads side to side on red and black pump leads: out of range (odd, I don't understand)
See pictures for details on the solar unit and pump.
I appreciate any help Dad can get with this! I was not there for any diagnostics, so all is second hand.
Travis
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Sounds like you have an open leg down hole. If you don't get any amps when hooked directly to the generator, then power is not getting to the motor. Hopefully it is just a wire, but most likely an open leg in the motor.
TJanak
South TX
Sounds like he's going to have the driller come check it out. Shoulder issues so he can't do it and I'm not around to help.
Any idea why the board/capacitor is burnt? He said the wires coming from the solar panel are one green and two gray colored, so thought maybe it was possible he hooked the two gray wires up backwards to the control box after testing solar panel directly to the pump.
TJanak
South TX
That sounded like a good cause.
Yes, except that in the sequence of events the board was not burnt until after wiring the pump directly to the generator and solar panels for testing, then putting everything back in the correct order and the board was burnt the next day.
Would there be a positive and negative wire from the solar panel? He is saying both leads from the panels are the same color and have no distinguishing features. Would hooking the solar panel back up with the leads backwards cause an issue like the burnt board?
And ultimately, is there an alternative to buying a new control box of the same make/model?
Joe Janak
Victoria, Tx
This the dad of Travis. Any further advice would be appreciated.
Everything Travis said is correct except the solar panels have only 2 wires both unmarked., no green ground (only the pump has a green ground). Could the 2 unmarked solar wires have gotten accidentally switched thus burning out the control board? Are they positive and negative wires going to the control box?
Thanks.
Joe
VAWellDriller
Active Member
Richmond, VA
Thanks.
Joe
It's been a while but I have installed a few of these Grundfos systems. I don't think that it matters how you hook up the 2 panel wires. Not sure how the board got fried, but it seems like right now you definitely have 2 separate problems.....the control board for sure and a problem in the well. The pump motor is either fried or you have a short in the wiring in the well. I would fix the pump first (which can be tested and verified with a generator) before you hook up a new control panel.
