Fleck, similar to Clack, have decided to no longer sell their new valve models to online dealers, due to lack of proper and knowledgeable support from too many of those online dealers. While the various types of 5600 models remain easily attainable online, the sales literature specifies that valve is appropriate for 10" (1.5 cuft) filter tanks, or 12" (2.0 cuft) softener tanks.
While I repeatedly see claims the 5600 will support 7 gpm backwash rate and therefore can be used on larger diameter tanks, a thorough review of the product literature clearly indicates the backwash rate specified, is '
Valve Alone' while incurring a 25 psi pressure drop. As such, there is no estimation provided for flow restriction through the riser tube, bottom distributor, gravel under-bed , the media itself or an upper screen.
As there are so many variables, Fleck has not estimated these flow restrictions but instead, state the largest tank size they are assured that valve will support, regardless of the media, water temperature and configuration utilized.
http://www.flecksystems.com/pdf/5600SXT-Spec-Sheet.pdf
