Before & After Simple Lab Results...Too Soft? Pentair 760 Tweaking Advice
TG284
Illinois
Hello All -- We recently added a whole home filter & Softener (+kitchen RO), and did some before and after SimpleLab tests. A little overkill for city water, but was looking to eliminate the Disinfection Byproduct that was detected in the first test, and soften our home too. Hoping to get some guidance on ideal softness and what tweaks you all would recommend. Also opinions & ideas on the 2nd tests detection of Dichloromethane. Since it wasn't present in the first test, I'm guessing its from the new tank/filter and hoping it will fade away, or was a lab tainted effect... Full details of the tests in links below
After Filtration/Softening: gosimplelab.com/AL8XS5 (Waited a few weeks after new system in place to re-test)
Before (if helpful): gosimplelab.com/SH88VC
I can also attach screenshots here if preferred.
Summary:
Hardness (Ca,Mg/Total) went from 130/130 mg/l down to .25./.85 mg/l
Sodium
went from 8 up to 78
Currently the Hardness setting shows locked, and at setting of 13, but if im able to unlock whats an ideal #
(2) Adults + 1 Toddler +2 more on the way
3000sqft 4.5bath
Equipment:
Pentair Autotrol Backwashing Filter 263-762-2.0 12X48
Pentair Autotrol Regen Softener 268-760-32 10X35
Let me know what other info might be helpful, thanks!
Summary:
Sodium
3000sqft 4.5bath
Equipment:
I did finally figure out how to unlock the hardness setting on our softener valve, changed Hardness from 13 to 10.
I'll try to attach those results here to avoid using the link
