Small question
hoolligan220
West virginia
Hey guys im kinda new to this so srry if the question may be out there and scattered brained but ya see i live out the country and my house is run off a well which runs really good but here recently for about a yr or so it seems like something in my well is causing my pressure switch to 1 constantly kick on and run and 2 run on bit lower pressure than what i reckon she should be at ( about 27-30ish psi) what do u guys think would normally cause these problems ?and for refrence its about 110ft well thats around 70 yrs ol or so
hoolligan220
West virginia
As far as brand, model,and hp kinda hard for me to get a read on it bein about 70 or so yrs old but thr depth is at about 109 ft
WHat i mean by constantly kicking on is regardless of whether i used/pumped any water u could hear the pressure switch being used/on/workin every few seconds likr every 8 to 10 sec
That fits hole in the drop pipe. Also fits badly leaking o-ring on the pitless adapter (if you have a pitless), or other bad leak. Could even fit failed check-valve at the pump.
hoolligan220
West virginia
Hi guys thanks for responses my problem kinda turned into a 2fer i got 1 fixed the 1 being well pump which is what it was and the 2nd problem being pressure tank which i will most likely need replacing soon
