Slow draining kitchen sink stopped draining after using drano!!
DennyJenny
Lousiana
I have a double kitchen sink with garbage disposal, it was draining very slow for a past few weeks. when I turned on the GD water backed up on the other side.
I used the Drano meant for sinks with GD and poured 3 big pots of hot water down it. they went fine. then I thot maybe i should run just tap hot water for a while..that water did not go, i turned the GD on and black water backed up (seemed like coffee granules) Some of that water went down..but now both sinkholes are evenly filled with water.
You have a drain line blockage, and the problem is probably in the walls or under the floor. Get your drains cleaned. Often the bottom of the blockage is where the pipe that goes down turns horizontal.
You are in LA, so it is unlikely that you have a basement.
You could try cleaning it yourself, but a little home snake will likely just punch a small hole thru the clog. I am not a plumber.
Stop putting coffee grounds down the sink. Throw away fats rather than using the disposal for that.
DennyJenny
Lousiana
found the blockage...hubby is using the snake now, it's right where it goes in the wall. we don't put fat as such....have Keurig so no coffee grounds :) Must be just the build up of many years! Thanks!
