Sink Drain - Can't Remove Connection from Stub Out
water_tight
NYC
So I'm replacing an old 1.5 sink drain pipe that's become brittle. My problem is that I can't unscrew the nut from the stub out in the wall. I only have about 2 inches to work with so it seems like cutting it off would just cause more problems. It is stuck real tight, I've tried penetrating oil and lime remover. Any suggestions?
I would try my 10-inch curved-jaw locking pliers. Rotate toward the movable jaw.
water_tight
NYC
I should add there's not much room to work with to get a long wrench in there. I can try the vice grips but I don't know how much a 10" is going to wrap around that nut
Jadziedzic
Active Member
New Hampshire
Try using a rotary tool (e.g., Dremel) with an abrasive cut-off wheel to score a line through the nut (parallel with the pipe) - don't cut into the threads of the stub out. You can then try prying in the scored line with a screw driver and that will likely crack the nut at the scored line, making it (hopefully) easier to spin off.
water_tight
NYC
That is a fantastic idea, will pull out the dremel tonight - you get a gold star.
I took my 10 inch Milwaukee curved-jaw locking pliers and tried some similar diameters, and it would be close. Those worked well on 1.5 inch galvanized for me, and that may be a similar diameter to that nut. I am not sure.
Some 12 inch or bigger Tongue and Groove Pliers with a jaw as pictured may be better for the large diameter.
That dremel thing sounds cool.
I have no clue if this is good quality, but it could be useful. https://www.sciplus.com/extra-large-locking-pliers-63862-p I have not had good luck with pipe wrenches. I had thought mine were good, but probably they are not.
Tuttles Revenge
second the cut off wheel in the dremel.. don't mess up the threads.. but if you do mess them up on the top.
water_tight
NYC
So just to follow up, mission accomplished. The Dremmel did the job, cut the nut and pried it off with a screw driver. One thing to note, not hitting the stub threads is easier said than done. You know you hit the stub when sparks start flying everywhere. Unfortunately I went through part of the threads so I couldn't use a regular replacement nut. I went with a waste connector (aka Marvel fitting) and some PTFE and was able to get a nice water tight seal.
Getting the old drain pipe out of the stub was also not easy, it was rusted into the stub and I basically had to slice it down the middle and pry it out piecemeal with pliers
Tuttles Revenge
Thanks for the update! Good job! It takes a skilled and steady hand to keep that blade from digging in or flying off. Before rotary we used to do that with a hacksaw.. downhill both ways... in the snow!
