Sink basket requires special tailpiece?
Kitchener, Ontario, Canada
Hi all, perhaps this is common knowledge and I just wasn't able to find my answer in previous posts...if so, I apologize.
I'm trying to install a new glacier bay single kitchen sink (model 4339FSS, if it matters) and it came with a strainer basket, but no tailpiece. I tried to install a standard brass tailpiece + nylon washer to it, but it doesn't have a flat sealing surface for the nylon washer to seal against. Is this common practice? Even home depot, who sells the sink, doesn't seem to have a suitable tailpiece that will mate to it. The sealing surface looks tapered and sharp...much like NPT threads on the end of a pipe...not a smooth sealing surface like I would expect.
It looks like it's designed to accept a tailpiece with a tapered washer of some sort, but I can't seem to find a suitable mate. Am I missing something? I got slightly frustrated and shaved the sharp parts of the threads off to make more of a sealing surface...and it's better, but still leaks slightly.
I *think* if I can get a tailpiece with a constrained rubber washer I can make it seal up, but I still feel like I shouldn't have to go this far for a brand new sink. Is this a quality thing I'm experiencing, or just some new design trend that I have to make work?
Thanks in advance for any help.
GReynolds929
Active Member
WA
Have you tried using the standard flanged tailpiece and top hat washer? It will probably seal just fine.
