Single stack vent with horizontal drain
Rusty Williams
Hi all, I have 2 bathrooms stacked in a way that does not allow for a continuous vertical vent. In the attached file, I'm questioning if the lower WC will need its own vent, or if IPC 917 Single Stack Vent System would still apply.
wwhitney
Berkeley, CA
IPC 917 Single Stack Vent does not allow that horizontal stack offset without venting the lower stack segment. If you can do that, then on first reading it appears to me to comply. But I'm not that familiar with the section and you should get a second opinion.
Cheers, Wayne
