Simple question about sill sealing a pipe combing up through concrete slab
Sam R
Seattle
Hi all,
I am a total DIY novice, but trying to learn. I received a lot of help here previously with this project and wanted to ask a simple question:
I had a professional jackhammer up a ~1 foot x 1 foot area of concrete slab in my basement and replace a leaking galvanized drain pipe (now ABS) and a floor drain that was attached, as well. They did a great job, but I now need to backfill the floor around the floor drain and ABS pipe and pour some concrete. Several threads (including here) mention wrapping sill-seal around the pipe first, before pouring concrete.
My question is, do I have the sill seal extending above and below the pour level? And how thick...like 4-5 wraps around the pipe and floor drain? And then do I remove it afterwards (leaving a gap) or do I permanently have some pretty pink sill seal sticking out (this would be totally fine - not a cosmetic area of the house and its over back behind a boiler). Will this lead to a gap around the floor drain that I don't want?
Sorry, I know this is a dumb question but I could not find the proper way to wrap sill seal around the pipe and/or drain anywhere on the internet - probably because it is obvious to the pros :)
John Gayewski
Iowa
I would use actual expansion foam for concrete. It comes in different widths. Get thr 4" width (or whatever thickness your concrete is) and do one neat wrap around the pipe. Pour the concrete. Then the expansion foam has a perforated top that pulls off. Leaving you a nice gap to caulk with np1
Sam R
Seattle
Wonderful, thank you so much! Do you usually wrap the associated floor drain too? Or is it better to leave that flush with the concrete after it is poured (no gap) for drainage purposes?
John Gayewski
Iowa
My opinion would be the same as above.
Sam R
Seattle
Cool, I'll give it a shot! Thank you so much for taking the time to help - very kind of you.
