Shower water pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lois Lane, Jun 26, 2021.
  1. Lois Lane
    Lois Lane Member
    Feb 22, 2018
    Detroit, MI
    Its me again! I am now replacing a 30 plus year old alcove fiberglass shower. The water pipes have always had hot and cold reversed, but I have adapted to that. Now that I have the pipes exposed, I was thinking about correcting this. This is what the plumbing looks like now. I would have just inserted a T each of the 3/4 inch copper water pipes at the bottom and run them up to the mixer. Is there a reason they come off the 3/4 inch pipe laterally? Should I just leave them alone where they come off the 3/4 inch pipe and cross them over to the correct sides higher up in the wall.
    Thanks for all the help I have gotten in the past on this forum. I apologize for not contributing my two cents, but as a rank amateur who learned to solder from You Tube it is worth just that...two cents.
  2. Terry
    Aug 17, 2004
    I would run some water there and make sure you know which line is hot and then mark it.
    Some valves can be reversed by the cartridge. It might have been a reversed cartridge and not reversed piping.
    Reach4 likes this.
    Reach4 likes this.
  4. Lois Lane
    Lois Lane Member
    Feb 22, 2018
    Detroit, MI
    I will check that! Thanks.
  5. Lois Lane
    Lois Lane Member
    Feb 22, 2018
    Detroit, MI
    Just an update to let you know, the shower was plumbed correctly, so I guess the problem WAS with the cartridge. You saved me a lot of tears!
Similar Threads: Shower water
Plumbing Forum, Professional & DIY Advice Kohler K-499 waterhaven shower tower problem Sep 9, 2021
Plumbing Forum, Professional & DIY Advice Old Shower Demolition (Permanently capping drain and water lines) California Sep 9, 2021
Plumbing Forum, Professional & DIY Advice Kerdi Shower Kit, Water Leak Test Failed Aug 26, 2021
Plumbing Forum, Professional & DIY Advice 1950s Pfister tub/shower low flow, just on cold water side Aug 5, 2021
Plumbing Forum, Professional & DIY Advice Shower Valve knocks and turns off water to a dribble HL - 40 Jul 25, 2021
