Shower Valve Trim Replacement
FrankPlumbing
South Jersey
Hello,
I am looking for a replacement for the shower valve trim in the attached picture in the relatively cheap price range ($20-$50). I don't want the red button temperature control type, just a standard lever that controls temperature, not the pull out to turn on type either. FYI, the screws on the existing trim are at 5 and 7 o'clock. Thank you for the help.
Unfortunately, what you WANT, and what you CAN GET, are two different things. Unless you also change the parts inside the wall, you can ONLY replace the trim with other versions of the same thing you now have.
FrankPlumbing
South Jersey
Thank you for the response. Do you happen to know what brand and model I currently have from the picture? There doesn't seem to be any indication of that on the trim. It was already installed in my house when I bought. The temperature control knob on the inner part of the lever no longer functions correctly and it is also starting to fall apart.
You might be able to get a better idea of who made it if you take the trim off and can picture the cartridge and valve body in the wall.
