Shower into toilet drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bill emery, Jan 6, 2019.
  1. bill emery
    bill emery New Member
    Jan 6, 2019
    indio calif
    Thanks for the add. i am new to plumbing. I am redoing a bathroom and was wondering if i could drain the shower into the toilet? Shower would have P trap 66 in run to 1.5 in vent line to the roof. Then 20 in line and connect under the toilet into a 3 in line. Toilet has its own vent line to the roof. thanks for any help you can give
  2. Terry
    Aug 17, 2004
    A shower can come in downline of the toilet if it has it's own vent.
  4. bill emery
    Jan 6, 2019
    indio calif
    Thank you
  5. bill emery
    Jan 6, 2019
    indio calif
    so i can have a shower drain then P-trap then vent, then toilet santee fitting with the 2in drain from the shower draining into the santee fitting then 3 in line out of the house? so the shower would be up stream from the toilet, all flowing out of the house
  6. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    The picture your words paint is not so good. Try a paint program to illustrate.
  7. bill emery
    Jan 6, 2019
    indio calif
  8. Reach4
    Sep 25, 2013
    You need a different fitting for the toilet. No santee in the horizontal for drainage. Somebody will have a specific suggestion I hope.
    California is UPC code, so your 66 inch should only be 60. Move the vent closer to the shower.
  9. bill emery
    Jan 6, 2019
    indio calif
    ok i can move the drain closer to the vent. it would be 40 in run from drain to vent
  10. Reach4
    Sep 25, 2013
  11. bill emery
    Jan 6, 2019
    indio calif
    drain 001.jpg Will this work?
  12. bill emery
    Jan 6, 2019
    indio calif
    For the fitting under the toilet would a combination Y 1/8 bend work? If I had to I would put a bushings in it for the shower to drain into
  13. Reach4
    Sep 25, 2013
    Yes. I thought that was Option A. So are are you picturing the closet flange centered above? So all of that is in the same vertical plane? That would be ok, but not required. That would put the 3 inch pretty deep.
    Option B looks good if they are in different vertical planes. You might try adding an overhead view to go along with your side view.
  14. bill emery
    Jan 6, 2019
    indio calif
    The 3 inch is very deep. This is under a mobile home. Lots of room down there. The closet flange would be centered above the 3 inch. Having 2 or 3 inches straight down under the closet flange then into the combination Y 1/8 bend then into the 3 inch drain. Everything is on the same vertical plane
  15. Reach4
    Sep 25, 2013
    Sounds good.
    The combination is combination of wye and 45 (1/8 bend). [​IMG]
    If you use the two separate pieces, as in the picture, that gives an extra point of adjustment if that is needed. The adjustment may not be needed.
  16. bill emery
    Jan 6, 2019
    indio calif
  17. bill emery
    Jan 6, 2019
    indio calif
    Is this what we are talking about
  18. Reach4
    Sep 25, 2013
    Yes. I was also talking about an alternative. I was not suggesting PVC instead of ABS.
  19. bill emery
    Jan 6, 2019
    indio calif
    Thank you for taking the time to work this out with me. I have the ABS fitting in the pic. It will go under the closet flange.
Similar Threads: Shower toilet
Plumbing Forum, Professional & DIY Advice Re-plumbing back-to-back toilets & adding shower drain/vent Jan 2, 2019
Plumbing Forum, Professional & DIY Advice Vertical Wet vent for toilet & shower? Dec 4, 2018
Plumbing Forum, Professional & DIY Advice Venting back to back toilet and shower Oct 23, 2018
Plumbing Forum, Professional & DIY Advice Sewer Ejector Pump Sucks the water from the toilet and possibly the Shower - How to fix? Sep 29, 2018
Plumbing Forum, Professional & DIY Advice Toilet drainage issue after shower Sep 12, 2018
