Shower base leveling
moe
Ottawa
Hi everyone,
I'm installing a new shower but the base itself is not leveled, I checked the floor and its perfectly leveled, is this normal?
Tuttles Revenge
The only thing that matters for level in a shower pan is the top of the threshold where the tile or shower surround will meet up with the pan. If you set the pan in the space that is when and where you check for level. The tiling flange can be wildly out of level because its not visible after finish surfaces are up.
WorthFlorida
Solutions
Orlando, 32828
Put the bubble directly over the drain cut out with the topside up. Is it in the center? The pan floor should all sloop to the drain. If not. A base of mort under the pan can do the final level.
