Arnold
I'm a handy DIYer working on replacing my old pipes with PEX. I feel confident with my research, design, and plan but I've had to replace a couple of sections of pipe in the past few years due to corrosion (hired a professional for those because it was an emergency) and I am concerned with making the final connection to the main when I actually get around to doing this. Image attached.
Optimally I would like to disconnect below the main shutoff valve, at the first elbow coming into the foundation, so I can replace the valve as I connect the new lines with a male iron pipe to PEX adaptor. Or perhaps I should start higher up, leave the existing shutoff (but install another) so I can move down to the next threaded connection point if there is a failure like stripped threads, pipe disintegrating, etc. I plan to connect new male to old female since it may be less corroded and less prone to strip(??).
So my main questions:
1. How concerned should I be about disconnecting old pipe from an old coupler and replacing with an new adaptor?
2. I plan to replace the main cutoff valve because I'm concerned that it's old and corroding but is that a baseless concern?
Other options I've considered:
1. Schedule a professional to make the final connection just in case something goes wrong, they would be on hand to fix it immediately.
2. Let scope creep set in and plan to replace the entire line from the street meter to the foundation (a friend recommended this to me). Sounds a bit beyond my budget at the moment.
Any recommendations, questions, tips/tricks/hints welcomed!
