Shallow well pump for large pond use
Michael Perkins
Vermont
i have an older goulds shallow well pump that is in my garage and is plumbed with a new foot valve. The intake is in my pond (not clogged). The output is connected to a garden hose. I use the pump to help aerate my pond. My problem us that there is little water pressure at the hose side so the water just shoots about 4 ft out into the pond. It is primed as water is flowing with no air sputtering. Do i need pressure tank? I run the pump maybe 5hrs a day with little effect. Any advice would be appreciated.
Did the pump provide the pressure you want in the past? If so, try cleaning the jet with a wire.
See #4 of https://terrylove.com/forums/index.php?threads/bad-pump.27241/#post-187628
Michael Perkins
Vermont
Michael Perkins
Vermont
So this is.my pump system. I have no clue how well it worked in the past as i bought this place in the fall last year. So what just happened while i was taking a pic is rhw pump shut off by itsekf then tuened right back on. Now it is shooting water like 12ft out into the pond.
Michael Perkins
Vermont
That will do!!! Thank you very much! I believe there might have been a contaminate in the nozzle that broke loose! Ill let ya know if there is a problem with it after this!
Michael Perkins
Vermont
Ok so the water output through my waterhone with a jet head on the end stopped spitting out water. Apparently when tbe pymp shut off and then right back on again having great water pressure, it was because we had a power outage for a few seconds. I closed the hose nozzle, closed the hose cutoff/on wheel and let the pump run to see if it would create enough pressure to shut off the pump. No bueno! So now im stuck right where i was before. Gonna go prime the pump again.
