So the ejector pump in the basement is sucking the water out of the toilet and most likely the shower. The fix seems to be connect the drain of the pump directly to the 3" main. Is this correct? If so, would the double wye pictured second to last be the way to go or have two separate 3"x 2" connectors one on top of the other?
https://imgur.com/a/172lAm2
Thanks for the help
Thanks for the help
