Sewage Ejector Pump - Switch recommendations?
Namber
Spokane, WA
Hello everyone,
We are getting ready to purchase and install an ejector pump in our currently unfinished basement. I am building a mechanical room near our main drain. For the pump, there will be about 8' of rise and less than 10 feet of run to reach the main drain. The pump will need to drain 2 toilets, 1 shower (single head), 2 lavatory sinks, and 1 bar sink. I'm also likely going to add an emergency floor drain. I've been researching a lot about the different ejector pumps and here is what I am leaning toward:
* Zoeller N267-0002: 1/2 HP, 115V, Cast Iron, non-automatic (Zoeller N267)
* Zoeller 18"x30" Poly Basin with 4" Fiberglass Hub, 2" Vent & Discharge, & Steel Cover (Zoeller 18"x30" Simplex Basin)
* Hydrocheck HC5000T Electronic Sewage Pump Switch with Programmable Cycle Length (Hydrocheck HC5000T)
Any feedback on the pump switch? Is there a better option I should use?
Thank you!
