Riccardo
Good Day all,
I bought a Fleck 5812 XTR2 with 2.5 cu/ft 8% cross link resin and was wondering what are the best settings.
What is the difference between down flow and up flow. Can i change that on the valve via software? I read somewhere that if there is a marking on the valve it should be down flow/up flow. Also what do i need to check for all the settings. Example Back flow Drain size etc. When i turned on the unit to check if it works it was set to time based regeneration which i think is not beneficial. I have water coming from the city and it has 28ppm with 5 people. I have read some post on the forum but i'm still confused.
Any help or advice would be greatly appreciated since the Fleck Manual doesn't really explain the benefits of down flow/up flow and regeneration type.
Than you much.
Than you much.
