Riccardo
other question, why should i leave the capacity at 60K and not change it to 80K
Turning this option on would the valve then do a regen after 30 Days even if i did not meet capacity?Day override/time: On/30
Using 100% of the resin's capacity, would require a large and inefficient quantity of salt every regeneration cycle. To regenerate all 80K in a 2.5 cuft unit would require 45 lbs salt (salt efficiency: 80K / 45 = 1,777 grains per lb) whereas 60K will require only 20 lbs (3,000 grains per lb).why should i leave the capacity at 60K and not change it to 80K
Frequently discussed, but still a good topic. You would need to use about 16*2.5= 40 pounds of salt every regen to get 80 K of capacity. Leaner salt doses give more salt efficiency. Leaner gives more hardness leakage.other question, why should i leave the capacity at 60K and not change it to 80K
Doesn't the water flow through the tank anyways when no regeneration is done?Setting a 30 day override, ensures the unit will be regenerated at least 1X per month, even when there is little or no water use. During regeneration, the resin will be reclassified (redistributed) and the water within the rank is replaced, thereby flushing away sediment and debris and keeping the water fresher.
Ah makes sense, when i tested my water it had only 0.1 ppm of iron in itWhen there's is no water being consumed, there will be no flow through the unit. It will be unlikely your softener will regenerate by the override setting but it is appropriate to program a reasonable setting in case everyone is away on an extended vacation, assuming the water remains turned on while you are all away.
The override setting is more often utilized for water containing iron. Depending on the iron quantity, regeneration may need to occur every few days so the override will ensure that occurs even when water usage is low.
So I will try to get a blue injector or even a yellow one. How do I calculate draw rate?A red injector for a 2.5 cubic ft softener is unusual. I would want to swap it out for either a #1 white (BD=80) or #2 Blue (BD=60). While longer brine draw can increase efficiency a bit, that increase the time that the softener is in bypass. Usually injectors are selected to take about 15 minutes to draw the brine, and BD about 4x (or at least 3 x) that time. Thus BD=60 is common. The symptom of BD being too short is some extra residual salt in the first gallons from the softener after it is back in service. I would ask your dealer to send you a #2 blue injector (or a #1). Some dealers would have supplied a #3 Injector - Yellow. That is bigger than optimal for a 2.5 cuft softener.
I would prefer your red to a yellow. White would be my second choice, but I think most people might prefer blue after study. It is close between white and blue.So I will try to get a blue injector or even a yellow one. How do I calculate draw rate?
Nobody should be up during that time of night and if so probably not using a lot of water. I read some statements from dittohead suggesting to have draw times longer as well so i might stick to the injector for now.Ditttohead advised to extend the Brine Draw time to compensate for the small injector. Will the longer regeneration cycle finish before anyone rises and starts using water? If the long regeneration is complete before water is needed, you may wish to leave the supplied injector in place.
Will change the time to 12:30, thank you much for the clarificationAs the entire regeneration cycle typically takes between 90-120 minutes, then Ditttohead's advice to increase BD time from 60 minutes (most common) to 110 minutes, will result in the regen cycle being extended by an additional 50 minutes. If programmed to commence at 2 am, regeneration may not then conclude until 5 am. If someone usually rises at 4 am to prepare for the day, then the longer than usual regen cycle may be a problem unless the regen start time is adjusted for an earlier time such as 12:30 or 1 am.
In adding the various 'step' settings you have shown in the chart in post #18, they total 156 minutes. The 27 minutes for Brine Fill may be subtracted as the softener will likely be able to deliver soft water to the home while brine fill occurs.
