Seeking advice on changing the fill valve of a Toto Pacifica CST804S
AL001
Seattle, Washington
Got a broken fill valve and the water just keeps running even after the tank is filled. It should've been an easy fix to replace the valve; but the problem with this toilet is that it is positioned in a tight corner and I've had so much trouble reaching my hand into the cavity that holds the connection of the water line with the valve tube, let alone using a wrench to un-tighten the bolt to disconnect the water supply line from the fill valve. This model seems to have gone some extra length to conceal the water supply line/tank connecting part and the connection is not on the surface of the tank but kind of hidden in an 'enclave'; and that it is almost impossible to reach in. Any advice would be greatly appreciated!!! Thanks in advance!!
See if this helps: https://terrylove.com/forums/index.php?threads/how-can-i-remove-this-nut-to-install-my-new-fill-valve.62114
