Mike Jarosz
Hello,
I am working on a bathroom renovation on a concrete slab. Toilet piping is finished, but still have access as the area has not been backfilled yet. I am trying to decide whether or not to install the my Oatey pvc 4x3 offset flange level with the tile, or on top of it. I have not cut down the toilet pipe yet, which is currently sticking up about 2 inches above ground level. I have read the discussions about this topic, however couldn't find the answer to the questions below. I would like to use the Sani Seal ring, however on the package it says "Gasket will not have room to compress if top of flange is 1/4" or more above finished floor."
Question #1:
The top of the offset flange measures about 1/4" think, so if it sits on top of the tile, this would mean that the top of the flange is 1/4" above the finished floor. Am I correct in thinking that the Sani Seal may be designed for when the top of a flange is flush with the tile or below it?
Question #2:
If I should just stick with a regular wax ring, do I need the type with the attached flange, since I am working with an offset flange? I'm not sure if the attached flange would seat correctly since it may hit the angled pipe inside the offset flange. I don't want to cause any more obstruction seeing that I had to use an offset flange and already worried about that alone.
Question #3:
What is the correct way to secure the offset flange? Since I still haven't not poured concrete yet, can I insert threaded rod into the wet cement, so that I don't have to drill in bolts later?
Thank you in advance!
Question #1:
Question #2:
Question #3:
