WellOff
Please excuse me if this is covered somewhere (I'd looked but didn't find anything).
In general the question is whether common household water pumping, filtration and treatment systems can operate under backup generator power. There seems to be a fair amount of electronics embedded in some of this stuff.
I am pretty sure that well pumps themselves are likely OK. In my case, and more of my concern, I have a Stenner pump and a Fleck sxt7000 backwash filter. The Stenner is plugged in to a small surge protector (in the outlet receptacle). The Fleck is plugged directly, w/o any such surge protector (not sure if I could get two on that outlet).
My generator is an older [circa 1993] Onnan/Cummins, diesel (Kubota) 7.5kW. I've tested this generator under load and find that it seems to produce very stable output: runs at 60HZ to 61HZ; voltage is also very stable (though I don't recall what the ranges were- I was thinking that the HZ was a bit more critical). This generator will serve my backup power needs just fine: my well pump is only 1/2hp (35' well). My electrical connections are all vetted.
Before I go to throw the switch to do a cut-over test of my generator I'd like to have confidence that I'm not going to fry any of my water equipment. I know to protect my computing equipment: all run off of UPSes, and I figure that I'll see what my household appliances think about this.
