LLigetfa
DIYer, not in the trades
I am looking to connect a 5000W portable generator through the exterior wall. The generator has an L14-30 240V outlet so I need a cord to go from it to a wall penetration box as well as the wallbox. I found the following but am open to suggestions.
www.reliancecontrols.com
Inside the house, I want to break out the 15A, 240V well pump circuit to a split duplex NEMA 6-15R where one side connects to the utility and the other side to the generator. I will need a 6-15P right-angle BX cord end plug that I can move between the two outlets.
www.leviton.com
www.leviton.com
If code does not allow a single duplex outlet to be split, with mains and generator to be in the same box, I will use two boxes.
All this assumes the generator can power my Grundfos 10S05-9 (1/2 HP) pump. This 5000W continuous duty generator is max rated at 6250W. The pump starts against a micronizer that limits the GPM considerably. Grunfos pumps use less amps at lower GPM so I am hopeful this will work.
Pump Electrical data:
Motor type: MS402
Type of motor: CSIR
Applic. motor: GRUNDFOS
Rated power - P2: 0.5 HP
Power (P2) required by pump: 0.5 HP
KVA code: L
Main frequency: 60 Hz
Rated voltage: 1 x 230 V
Service factor: 1.60
Rated current: 6 A
Starting current: 410 %
Cos phi - power factor: 0.76
I will rely on the generator's breaker for over-current protection.
WKPBN30 Transfer Switch Accessory - Reliance Controls Corporation
WKPBN30 Transfer Switch Accessory - Reliance Controls Corporation - Manufacturers of Transfer Switches and Panels for Portable Generators. Toll-Free Information (800) 634-6155. Product details,manuals, install video and information,vendor locator,product selector,troubleshooting,product support
PB30 Transfer Switch Accessory - Reliance Controls Corporation
PB30 Transfer Switch Accessory - Reliance Controls Corporation - Manufacturers of Transfer Switches and Panels for Portable Generators. Toll-Free Information (800) 634-6155. Product details,manuals, install video and information,vendor locator,product selector,troubleshooting,product support
5031
5666-CA
Motor type: MS402
Type of motor: CSIR
KVA code: L
Rated current: 6 A
