BillyPilgrim
Hi
I just moved into our 2 story house of 1600 sqft near Vancouver BC and it has an older gas furnace, not sure how old the furnace is.
The problem I am having is that the ground level floor is very cold and the upper main living area is nice and warm. When the furnace runs the ground floor heats up fairly well but as soon as it stops all the heat travels upstairs and the ground floor is quite cold.
THe thermostat is on the second floor and only has two wires running to it so I can't run the fan only. I'm hoping someone can give me some advice on how to run the fan only on my furnace. Maybe on a switch or timer or run a new wire to thermostat. I'm hoping that running the fan will even out the heat in the house.
Pic of furnace here:https://plus.google.com/111042771435208504902/posts/XydQZj8X2ba
