Want to run Furnace fan on continuous
Rockycmt
New York Metro Area
I have a Hot air oil furnace. 2 wire thermostat. I have a few wood burning sources in the house. But I want to use the furnace fan to just circulate the air to spread the heat throughout the house. I typically never need the oil burner to go on even in sub 0. Some bedrooms do not get the heat from the other sources. If I can run the furnace fan through the night then the whole house will equalize. I sometimes cycle the heat for several min to build temp on the furnace just to run the fan for a few minutes. The Fan currently goes on when the firebox gets to temp. Is there a way I can bypass that with another power source?
Thoughts?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
If the furnace control board has a "G" terminal, then you would just need to run wire to accomodate the G wire to a new stat with 'fan on' capabilities.
Fitter30
Peace valley missouri
Your fan control might look like this one. It may or may not have the white plastic knob sticking out of the cover. If it does just pull it to turn the fan on. Under the cover will either be three or four wires. One side is the fan the other is the limit don't turn the center round dial. One marked fan can follow the wires back put a switch across them.
