Rough DMV Water Test Dropping...
Soonermagic22
DFW Texas
Hello,
I was hoping for some reassurance on some under slab plumbing. I am currently building a home and I am at the stage of just finishing the above ground rough DWV. After getting all the pipes filled up fort he water test, I found after 24 hours the water level on a 3in drain had dropped a little less than 3/4 of an inch. I Just don't want to get the foundation poured and find out it's a bigger problem than what my plumber says it is.
probebly air in system if air can get locked inside it will absorb water and the level will drop, likely no problem
dont know how you built a house and havent poured foundation
