Rinnai i120c combi boiler losing pressure (error code 430)
SalMazz
New York Rockland COunty
Help system was working from February 29,2025 until March 12, 2025 with no error code E430 once I adjusted the circulator. Now I am getting the E430 on occasions sporadic. Any thoughts maybe pressure switch?
Fitter30
Peace valley missouri
What's the water pressure? Minimum is 13 lbs.
SalMazz
I have been in touch with Rinnai, and it seems that the E430 error on the combo boiler is due to sediment buildup causing the issue I was experiencing. I cleaned the filter screen under the boiler, which was dirty, and I plan to flush the system with vinegar. Additionally, I will flush my heating lines with a cleaner, isolated from the heating unit, when the weather permits. My pressure was fluctuating by the way and I did not see this at first but when I checked probably due to what I mentioned above. Hope this helps someone who has a similar issue.
SalMazz
help still getting e430 code with Rinnani Combo boiler. It happens even when not asking for any hot water just when it cycles. I can't figure this out. Had posted pictures before maybe if I can I post a video.
SalMazz
Shaft of the motor needs to be horizontal, not vertical or diagonal.
That was not the issue on the Rinnai boiler there is a factory setting that needed to be changed. The factory setting is for having a setup where you have continuous hot water as soon as you open the faucet. This is in the fine print and caused E430 error code.
