Rheem PVW50 water tank runs for over 1 hour
Duffer
Ottawa, Ontario
I have a Rheem PVW50 water tank that runs for over 1 hour after a few minutes in the shower.
It started doing this a few weeks ago and I am planning on getting a new one installed tomorrow.
The tank was installed 21 years ago and I had it completely serviced about 8 years ago before I did a buy out.
Any ideas on what would be causing the unit to be constantly running for so long?
It previously ran to heat the water but would shut down within a 8-10 minutes.
Just wondering if there is something that I can get the technician to check and repair instead of having to replace the entire unit.
Thanks in advance.
Phog
Active Member
Rochester NY
For a sudden change like that, with no other accompanying symptoms of malfunction (like temperature / pressure relief valve opening), it would be likely that something got partly clogged by debris. For example the gas orifice is partly blocked, and you're not getting enough gas flow to get the full BTU's out of the burner.
But whatever the problem, I think installing a new unit is the most cost-effective path forward. 21 years is pretty old for a water heater. At minimum you're going to spend a couple hundred bucks on a repair, and afterward you'll still have a 21 year old tank that is likely nearing end-of-life.
It's a bit like having an engine tune-up done on a 97 Chevy Blazer with a rusted out frame and holes in the floor pan.. Sure you might be to make it run better, but does it make sense to spend money on that vs. getting a new car?
PS - Go Sabres! :D
Is that an hour of flame, or is that an hour of the power vent running? If the flame was running for an hour, I would think the water would get too hot.
Duffer
Ottawa, Ontario
PS - Go Sabres! :D
Thanks for the input..
I have a guy coming tomorrow to do the new install.I like the sabres too but the Knights are a team to watch...
