Reuse exploratory well for irrigation
rktman
I have an old 8" exploratory well on my place that is 950-1000' deep. Water appears to be clean with no hydro-carbon odors. Static water level is around 20'. For an irrigation type well, what kind of pump setup would be common?
I don't have permanent power there and I'm thinking a portable 10k generator would work.
Thanks
Bannerman
Ontario, Canada
What GPM do you expect will be required for irrigation?
Is your 10KW generator capable of delivering 240 volts or only 120?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
I would get a cheap pump like one of these. https://www.ebay.com/p/2152858266
The 2HP will still pump 15 GPM from 340' deep. I would set it about 350' and test the well. Running a 1/4 poly air line down with the wire will let you measure the actual water level while testing. Once you determine the pumping level and amount you can pick a pump and depth of setting as needed.
