Rerouting Radiator Pipes
Greg Pizzola
Pennsylvania
We are renovating our kitchen / dining area and had removed a partition wall which was hiding some pipes to a second floor radiator.
Goal here is to reroute the pipes backwards and then down through the top plate of the new wall.
My original idea was to turn the elbows a quarter turn so they would now face horizontally which would give more ceiling clearance, then insert male copper adapters and run new copper back and down through the wall.
Needless to say there isnt much to grab on these elbows and 100 years of sediment have frozen them in place.
I should have just enough clearance for the drywall if i instead insert male adapter 90s in the iron elbows.
Anyone see any issues with this method? Not being a plumber, I guess my main concern is all those 90s (4 in this area alone) needed to keep the plumber in the ceiling.
Pics included. I used some 3/4 elbows i had on hand in place of the male adapter elbows i would need to purchase, just to show the idea...
Tuttles Revenge
Theres no issue with your method. But maybe a threaded Street 90 first so you're not heating up your threaded fitting. Then you can pre solder your Male Adapter with a length of pipe first. Then the next fitting is far enough away that you can mitigate the heat with a wet rag to soak the heat before it hits your threaded connection.
Michael Young
North Carolina
looks fine to me, as long as you're not reducing the pipe diameter. Be sure to insulate as much as you can after you've tested for leaks.
