I just replaced my softener system. A new water test, increased family size, and getting a little more efficiency out of a metered system convinced me to just replace it.
But now I have my old 5600 w/ 8x44" softener tank and 5600 w/10x54 nitrate tank sitting off to the side, just staring at me.
I have the following setup:
Submersible 3/4hp 10gpm well pump ->
Check Valve ->
Cycle Stop Valve ->
1" Pressure Tank ->
1" 50 Micron Spin Filter ->
Big Blue 4.5x20" 5 Micron Cartridge Sediment Filter ->
1" 12x52 / 2.0 Clack Softener ->
3/4" - 15GPM UV ->
3/4" House trunk
I'm staring at that 5 micron sediment pre-filter and I'm wondering if I'd be able to repurpose one of the old tanks. The 8x44 might be too small for anything but the 10x54 might still be useful.
I also figure the lack water metering isn't as important with a media filter as that would be more time based, is that a reasonable thought?
My water has trace amounts of uranium (0.006PPM). According to EPA activated alumina is good against uranium. KL has also listed as being able to reduce trace amounts of it. So I'm considering opening and cleaning the 10x54 and just filling it up with KL to address that.
There's some reading that suggests GAC may have a minimal impact on uranium - and definitely on radon, so another thought is potentially just replacing my 5 micron sediment filter with the 10x54 and convert it into a GAC filter and then retest to see how that goes first.
I'm thinking I should be able to just remove the injector and/or plug the brine line and replace the resin with media. Does anyone know the right way to approach this?
Check Valve ->
Cycle Stop Valve ->
1" Pressure Tank ->
3/4" - 15GPM UV ->
3/4" House trunk
