Chris Milot
Hello everyone, this is the first time I've done anything with plumbing but am pretty handy so thought I would try this. We bought this house which had a utility sink already installed but the drain came out from right behind the dryer and the water supply was just tee'd in at the washer outlet. We are redoing the tiling so figured while I had everything out of the laundry room would attempt to get the drain and the water supply line behind the wall to clean up the look a little.
The utility sink they had previously was just one of those cheap looking ones with 4 legs so I plan on getting a utility sink that has a cabinet surround (Vanity). I'd prefer not to have to drill holes in the side of the cabinet to run the drain and water supply lines and that is why I'm trying to put these behind the wall and come out in the back of the cabinet.
I've got the dry wall removed so just looking for some advice on the best way to do this and to make sure I'm not doing anything against code. Here are some pictures
So if you see in the first picture where the PVC pipe comes out of the wall and goes left, that was for the utility sink previously. I'm wanting to have that behind the wall. Would I just cut out that tee that is currently there and put one in but have it rotate so it goes through the vertical stud to the left of it? It looks like the pipe going down is 4". What size should the line be coming out to the sink?
And for the supply lines it looks like I can just tee off the copper pipes that are right there . Any issues with that?
Sorry for the basic questions I just don't want to do all this and then realize I did something I shouldn't have.
