marc4790
Hello. I have removed the tub and am in the process of constructing walls for a walk-in shower. My plumbing question is:
Do I need to install a P-trap to the existing tub drain below the slab or can I safely assume that a trap was installed when the tub was set? The 2 inch pipe seeems to comes straight up from a sand bed below the slab, but I can not see below unless I dig down into the saand below the slab. there is a 9 inch by 12 inch opening in the slab around the pipe.
Thank you for sharing your time,
marc
marc
