Replacing leaking shower supply pipe without opening wall
tonyttt
Philadelphia, PA
Does anyone have any tips on how to run a replacement shower supply pipe without opening the wall? I have access to the rear of the valve. I was thinking I would remove the copper supply line going to the shower from the valve, and install a pex adapter, run pex straight up the wall replacing the copper. I would attempt to remove the copper by dropping it a bit at a time and cutting sections as I go. The elbow does not appear to be tied in as the head moves front and back quite a bit. I would first cut the elbow off through the shower head hole and attach some line (to assist in snaking the pex) before trying to drop the pipe down. With the pex in place, I would tie in a new elbow, maybe trying to tie it to a cross member if there is one there. If there is no way to secure it, perhaps blow in foam to hold it in place.
Are there better ways to replace the line??
Thanks
tonyttt
Philadelphia, PA
Could not get the PEX run without opening the wall. need to replace a few tiles and figure out a way to secure the elbow at the top. The prior copper tube and elbow were not secured to any framing. The gadget in the picture threaded into the elbow is a section of scrap I had with a valve being used to pressure test the repairs, I didn't have a 1/2 plug available for the test. I should have opened the back wall but I try to avoid dealing with plaster.
Dj2
California
From the pictures, I see that you have created a big mess.
How are you going to finish the tile work?
tonyttt
Philadelphia, PA
The tiles I used originally are standard white so it was not difficult to replace the backing, waterproof and replace the tiles. Its all back together. My one mistake was not checking the condition of the valves. I may have replaced the entire valve had I checked and found that the diverter and hot stem needed replacement. I purchased and installed a Danco kit which included stems, handles, trim and seats so this old Central Brass valve is good to go for a number of years.
My initial dream of disconnecting the copper shower supply riser from the valve, pushing it up and out of the way and running pex up to the existing shower head hole (without opening the wall) was a pipe dream but it all worked out.
I am happy that I went in through the tile side as opposed to the back wall since that wall faces the entry of the apartment and it would have been difficult to match the custom paint that was used on the wall.
