Replacement window recommendations?
Gdog
write diagnostic firmware for embedded industrial
back in PNW
In SE MI; house is a bit over 20 years old, original builder windows are cheap and need replacement.
Looking for quality and value; i.e. highest R capability and noise attenuation as possible w/o taking out a large loan..
Anyone have experience w/these guys? http://www.windowuniversedetroit.com/prices.htm
TIA!
My preference is a window with a fiberglass frame. The fiberglass has about the same expansion/contraction ratio as the glass, so it puts less stress on things through the seasons. This should make the seal on any gas-filled glass assembly last longer before it leaks.
Fiberglass can be had with smooth surfaces, or on the inside, a wood-grain, so you can stain and finish like wood if you prefer.
So something like the Elevate line at Marvin; yes?
