Hi everyone,
I currently have two 50 gal gas water heaters supplying hot water to my home. It's a large home with 5 bedrooms, 6 bathrooms currently occupied by a family of four (myself, wife, and two kids). None of us has ever ran out of hot water. We will potentially be finishing the basement at some point, adding another 2 bedrooms and 2 bathrooms.
Recently I found a new leak coming from the bottom of one of the water heaters. The heaters are 16 years old and I think it's probably time to replace. My question is, if I decide to replace both water heaters, should I replace them with two 50 gals again, or could I just replace them with a single bigger one? Would I gain anything by doing this?
Additional info:
From what I can tell, the water heaters seem to be independent of each other, meaning they have separate hot pipes servicing different portions of the house. They are, however, sitting side by side in the basement. They share a recirculating pump with the line connected to the bottom drains of the heaters. Only one of the tanks has an expansion tank (the one that's NOT leaking). The pressure release is pipes are directed into a sewer pvc, so I couldn't tell if pressure is being exceeded. I've replaced a water heater before but this setup looks really complicated to be honest.
Additional info:
