Removing chlorine but keeping fluoride
rural_engineer
New York
I'm considering a filter to remove chlorine from my city water to preserve my PEX life span. I don't want to remove fluoride. Will a carbon filter meet my needs? Anything else I should consider?
Sylvan
Still learning
New York
Would it be possible for you to find toothpaste or mouthwash that contains fluoride?
Personally I would be more concerned about the possibility of toxins leaching into the potable water supply by petroleum based plastics.
rural_engineer
New York
The relative merits of fluoridation and PEX are not the topic at hand.
I am interested in how to reduce chlorine without reducing fluoride.
Removal of fluoride by GAC is much less than removal of chlorine.
I don't actually want to use https://www.allfilters.com/waterfilter/fluoride as a source, because they imply fluoride is a heavy metal, when it is the opposite of a heavy metal.
https://pubmed.ncbi.nlm.nih.gov/18538069/ says
"Results: Hollow-fibre membrane filters did not affect fluoride concentrations in the fluoridated water, but activated-carbon filters removed some fluoride, especially from the pure-water solution. Filtering a pure-water solution with a fluoride concentration of 0.8 mg F/L reduced the fluoride concentration until 210 L of the solution had been filtered. However, filtering a tap-water solution of 0.8 mg F/L reduced the fluoride concentration only until 8 L had been filtered. The concentration of absorbed fluoride in the filter at 10 L of filtration was 4.7 mg/kg activated carbon."
