Shoes
Hey folks, first time post.
I am going to replace my house Polybutylene with PEX. I am on a well. The previous owner had a small section near the intake replaced when they installed a water filter, I will do the rest of the house to be PB free.
My question relates to a section of PB coming off the bladder. They replaced most of the PB with Pex at the intake except the first couple of feet by the bladder (not sure why?). This will be the first thing I replace. My question is regarding where this PB connects to the bladder at the bottom, near the floor (not the connection to the PEX): Do I use a crimp cutting tool to remove the copper crimp around the PB where it attaches to the bladder, or should I remove that fitting that it is crimped to (it has the form of a nut)? Im not sure what Im looking at.
My plumbing lingo is limited, be kind
Two pictures. Here is the high level view, where you can see the two feet of PB which runs from the bladder to the white PEX:
The second image is the close up of the connection to the bladder. How would you remove this final PB connection?
Thanks for the help.
Shoes
Shoes
