phils
I have a Goulds V250 pressure tank that has a 40/60 drawdown of 4 gals. Not the 22 gals I got when it was new. Is there anything else I should check before putting in a new pressure tank?
A little history...
The system was installed 10/02 with a Goulds pump 1/2 HP #10GS05412 and a well-x-trol #302 pressure tank. The well is drilled to 50 feet with the pump set at 35 feet. The pressure tank is buried in ground with the top of the tank at ground level.
The Well-x-Trol tank failed in 03/08 (drawdown was 0) and was replaced with a Baron pressure tank #BN17002.
The Baron tank failed in 02/11 (cought this at 5 gals drawdown) and was replaced with the current Goulds V250. This one being inside the 5 year warranty was covered by the warranty.
Yes, this will be my 4th tank in 16+ years.
Both my neighbors had their wells drilled in 2002 at the same time mine was drilled. One of my neighbors well head is literally 30 feet from my well head and his pump is set at the exact same depth as my pump. Both of these neighbors are still using their original Well-X Trol #302 pressure tanks. All three were done by the same company (a highly respected driller in central Texas) and both neighbors have buried tanks like mine.
Back to my original question... Is there anything I should do/check before replacing my pressure tank yet again?
Any thoughts on why my tanks keep failing?
We have only had one incident/issue with the well, the well delivered dirty water (water with lots of sand), this occurred in 2014 (5 years ago). We flushed the well/tank/lines until the water ran clear again and have had no issues since. The drawdown at the time this happened was checked (after the water ran clear) at 20 gals +/-.
A little history...
