AP1
This forum steered me to an awesome new toilet (Toto Entrada). I'm wondering if the same thing can happen for a replacement tub/shower faucet.
I want to have an old Delta "ball" faucet replaced. It's the kind where you pull the "ball" up or down to change pressure while turning it to change temperature. It can be a real pain to use (to get just the right pressure and temperature you want). Our other shower has an old basic Moen faucet where you pull/push to change pressure and turn to change temperature. It's much easier to use.
I'm wondering what plumbers are using and recommending these days. Both our faucets are very old and I'm wondering what the best current faucets are.
Considerations:
Thanks in advance!
Considerations:
- Easy to use -- don't have to fiddle with controls; it just works
- Separate pressure and temperature control -- not like some where you only get hotter water by turning the pressure up
- Quiet -- doesn't "squeal" or make noises inside the faucet or valve depending on the water pressure
- We tend to use lower water pressure (not full blast); our current faucets tend to make noise when the water is "restricted" like that
- Dependable and long-lasting -- handle doesn't get stiff over time or need to be regularly lubricated or maintained
- Nice basic control for one shower head
- A good value -- I'm willing to spend a little more for good quality, but I don't need super high-end
Thanks in advance!
