2002sheds
Hi,
I have an "open system" that supplies hot water for both radiant floor heating and domestic hot water. Our needs for the building have changed, and there is now a small kitchen and bathroom that receive hot water. Since the system is open (no check valves to prevent water from coming from the radiant tubing and back into the system after the heater), I would get slugs of cold water along with heated water at the 2 faucets and from the shower.
I have isolated the issue and confirmed that there is cross over via the radiant tubing (the structure has 2 stories so gravity is feeding at least some of the water from the tubing back into the line, post-heater) by shutting off the supply and return valves to the radiant tubing. Once I did this, hot water arrived quickly and consistently to the fixtures. We are in a temperate climate and it is summer anyway, so there is a little bit of time to solve this without having to turn the radiant system back on right away.
The hot water line has two short runs (like a capital F), so that the top short line in the F supplies hot water to the radiant tubing, while the other provides domestic hot water. My idea is to simply insert a check valve between the two, so water from the radiant tubing cannot back into the domestic side.
Is this stupid? Correct? Other?
Thanks,
David
Thanks,
David
