Question about PEX and Rodents
Kubstix
Pennsylvania
I am currently demoing my garage ceiling (drop ceiling) in order to replace insulation in ceiling and doing 5/8 sheetrock (living space above). I currently have CPVC in my house and I am replacing my entire house with Uponor. My main line from the well tank to the back of the garage where my filters are going to be mounted is roughly 20 feet and is 1" PEX. I am going to be running parallel with a joist and going over the top of my main support beam (I have about a 6 inch clearance above beam and joists) where I will drop down in the back of the garage. Once this is sheetrocked, that's it. My question is has anyone ever ran a 1" line inside another line like perhaps a 1 1/2 PVC pipe or a 1.25" galvanized pipe or something of this sort? I want to make 100% sure I am rodent protected because I would hate to have to cut into sheetrock in the future. Thank You.
JohnCT
Still learning..slowly
Northeast
I think that's a good idea.
I suppose you could also use a foam insulation sleeve (which Uponor says is OK to come in contact with the PEX) and then wrap the insulation with something the rodents don't like.
John
WorthFlorida
Solutions
Orlando, Florida
....My question is has anyone ever ran a 1" line inside another line like perhaps a 1 1/2 PVC pipe or a 1.25" galvanized pipe or something of this sort? I want to make 100% sure I am rodent protected because I would hate to have to cut into sheetrock in the future. Thank You.
Good idea but will there be any bends? If yes then use electrical PVC conduit at the bends. Comes in all sizes and white PVC and electrical PVC are sized the same.
Kreemoweet
Seattle. WA
I've had rodents chew right thru PVC, ABS, and PEX piping (stored, not in use). Squirrels will also chew the bejabbers out of plastic items,
if they get the chance. If I had to protect my piping from vermin, I'd use flexible metal conduit.
